oldmisterbill
Grumpy Old Man
My thoughts. I don't know the details of the whole situation. Every body here is correct. Hydraulic is nice ,expensive ,long lasting,Not so portable but real good. Cheaper winches don't last as long. 100 ft cable -i haven't seen one on a winch but a snatch strap or chain will give you what you need. My experience -
I had a 18ft bumper pull,didn't have the $ to buy what I really wanted -a 12000lb pull Warn winch. I got a superwinch 2500lb pull with a snatch block. It was great for loading dead cars and smaller tractors.It got smashed pretty hard once,I needed it and the factory was only 60 miles away,off I went. The didn't sell parts at the factory (you have to go to a dealer) but for $30 they would repair it ,didn't matter what was broke they would fix it for $30 done while I waited. It looked brand new-new cable control -NICE!! That was in the late 1980's.It was at the shop at least 5 times from being over worked hit or some kind of abuse. Yes it should have been heavier. Then I got my 30 ft trailer no $ to buy a new winch I used the old one with that trailer also. I loaded 4-5000 lb tractors,on a couple the wheels wouldn't turn just slid up the ramps with a snatch block. 20 years later still gong I mistakenly showed the trailer to a potential buyer with the winch on it.He is still using that same old winch.
20111 super winch has a 4000 lb winch with a limited lifetime warranty.No it doesn't have a cordless remote,neither did my old one I made an extension cord 50 ft.so I could load and sit in the vehicle being loaded. What you get has to fit your budget - if I had a strict limit on what I could spend this is what I'd get.
Super winch 4,000 lbs
