you mean a wet shirt or a wet towel over the line.Also throw a towel or a t-shirt over the line. That way if it does break the towel will absorb all the energy and the line wont whip around like a bat outta hell.
Check out Harbor Freight for winches. Get the one that is remote control. That way if the truck is stuck you can drive it an still pull with the winch to help. They have a sale on them every now and then. Yuo will need one with a hundred foot cable. I had an 8000 lb one, it worked great.
hydraulic winches can tear a truck in two
I have put my money in Ramsey 9000lb winches in my trucks over the years and they have brought home the bacon with minimal maintenance.
I totally agree Ramsey is top shelf - but pricey. If you use it a lot its the only to go,hands down.
I just wanted to add one more thing here. I ran a welding cable from the battery in the front of my F250 to the rear,and one Through the grill.Next I got a couple of the electric forklift battery connector plug in (they come in different amp ratings. I had a battery mounted on any trailer I had charged by the vehicle with a 10 Gage separate cable. I welded a square receiver tube on the trailer ant to my cattle catcher mounts. I could move the winch any where in a minute -un plug,pull the pin , remove the winch & put it where I needed it and no problems with voltage drops & not enough power to run the winch.
I still say bang for the buck (Thanks Brad) super winch has the customer service -afford ability to get it repaired (remember every repair is a rebuild) and is more affordable for the casual user & as i said I have dragged dead 4000 lb + tractors on a trailer with the rear wheels locked using a snatch block-(on one tractor I did use 2 snatch blocks) So when $$$ is short there are ways maybe not as nice as the big dollar winch but it can be done.
you mean a wet shirt or a wet towel over the line.![]()
all kidding aside, a dry t-shirt or towel will do little slowing down a line.Dang it Calvin, you'll do anything to see something in a wet Tshirt![]()
might wanna look into promark winches. they were gorilla winches but changed the name. i got mine ready to bolt on 12k wireless and corded remote shipped to my door for 410 $. didn't expect much for that cheap but its a beast and has been trouble free and i use it every weekend . i have it mounted just in front of my gooseneck ball so i can use it to winch stuff on my trailer and pull rigs out when im wheelin .
it doesn't compare to the 20k tulsa pto in my wheelin truck but with 2 optimas and a deep cycle semi battery behind it , it does everything i need it to and i never use a snatch block on it . drug a 17k 4x4 petibone loader through a 3 foot snow drift dead weight to get it unstuck for example . i was shocked to say the least i didn't think it was gonna do it.
I'vee seen the results of a Chev HD3500 and a wire rope that broke. the cab of the truck was almost cut in half.
hydraulics is no joke when wire rope is involved.
