93turbo_animal
ok the OBS PSD has a mechanical fuel pump too so no relay for it either. I've never seen a IDI with an electric pump of any kind stock that is. If you read the aplication on autozones site it says for gasoline applications on that relay you found. I know alot seem to like the electric pumps but I don't see any advantage to out weigh the hassle. I've changed IP, filters gallore, and the lift pump and never had an issue restarting the truck and it only takes about 20 minutes to change the pump and I'd probably still be running the original pump if I hadn't been chasing an air leak and thought it was the pump. If you want an electric pump with a back up I'd say just make everything easy to swap out an carry a spare in your truck cause one just riding around under your truck may not work by the time you need it anyway
