Please listen to the attached audio. No known correlation to anything. With windows up, it sounds like it's coming from the transmission. With windows down it sounds like it's from all around. Gear does not matter - i've heard it in 3rd, 4th, 5th gears. Clutch in/out does not matter. The truck must be warm...after 15 minutes of driving minimum, and it happens more often on hot days. It does not affect vehicle performance, and does not cause any fluctuations in gauges. Last night I drove it for 45 minutes, and it happened once, for 1 second. The day before when it was hot, it was happening intermittently every minute or so. Any ideas?
Recent work that was done:
Driveshaft: new center bearing and u-joints, professionally balanced
BW1356: self-rebuilt, new oil pump
ZF-5: self-rebuilt with full mainshaft teardown, shifts great
Clutch: New LUK SMF, 12.25"
Engine: professionally rebuilt Heads
Fuel: Baby moose, rebuilt injectors
