nicksorenson
I always hear PowerStrokes whining pretty darn loud. I can't hardly hear my IDIs turbo at all. Just wondering?
Having both, I think I can fairly say that "it doesn't have to be louder". As was already mentioned, there are certainly design differences that will amount to some difference in noise. In my case, both my turbo IDI's are manuals, and do not have to turn near the R's to get moving as opposed to the PSD that will move like a slug up a hill turning 2K with the trans slipping away because you can't make 35MPH to get it to lock up. Most of the noise from a stock PSD comes from under the hood. You don't get any turbo whistle out of the exhaust, and what you do hear either comes from the turbo itself, or out of the air intake. With both IDI's running no muffler, I can hear the turbo way better than on the PSD. Granted, apples to apples and stock to stock, the PSD is louder, but the other possible explaination is turbo blade design. The noise a turbo makes is actually a result of its inefficiency. The rougher the edge of the blades the more noise its going to make. Since the PSD turbo does produce more boost, I suspect it is spinning a bit faster most of the time by comparison also.
I don't think I explained it very well. The speed limit is 30. It's a steep hill. With my IDI's I can all but idle up that hill, while the Excursion sounds like it's trying to make a mountain out of a molehill. That's the problem with a transmission that shifts based more on speed then load.
Tonka... Don't you just love those cruise controls.... Like Ron Popiel says.... Set it and forget it.....
