Christopher Cline
I have a 93 Idi original motor, 286k,new injectors, pump with idk how many miles on.
Right now I’m having white smoke on start up. Once it’s warm it’s just a haze and won’t really smoke cruising town but if I romp on it it puts out a blueish white smoke. Cruising on hwy it will sometimes have a steady haze of it. I compression tested and 7/8 were 395-400 ish and one was 385. That same cylinder had some funk on the valve cover while I was replacing gaskets. Not a lot but a little bit
Do you guys think this is a valve seal? Bad rings? Or IP?
Also do these have dual valve springs stock? Mine has the outer one and a smaller one inside it and was wondering/hoping there’s already been a head job done.
