ColLonewolf
Which ZF transmissions bolt to the IDI? Will any diesel ZF bolt right up or only one from a 7.3L? Will the ZF-6 bolt to the IDI? What do you use for a clutch if so? Thanks.
The ones that came on the back of IDI's. Or if you look in the tech articles you can find an informative page about modifying a gas 460 ZF to an idi.Which ZF transmissions bolt to the IDI?
Not sure i understand what you are asking. The 6.9 and 7.3 bolt patterns are the same.Will any diesel ZF bolt right up or only one from a 7.3L?
This question can be answered by searching the forum. It's been covered several times.Will the ZF-6 bolt to the IDI? What do you use for a clutch if so? Thanks.
Rock you sure about the SD being different? The back end of a 6.9 or 7.3 are all the same . Whcih would mean the trans bellhousing is the same. It would be odd for the SD to be different.IIRC, all the diesel zf5s from 88' to 97 will interchange between IDIs and obs 7.3 powerstroke, but the superduty trucks have different bell housings. The zf6 will not bolt right up, but if you got deep pockets and high expectations, go for it Lol.
Rock
It'll bolt up, but the spacer is different.Rock you sure about the SD being different? The back end of a 6.9 or 7.3 are all the same . Whcih would mean the trans bellhousing is the same. It would be odd for the SD to be different.
Beat me to it!It'll bolt up, but the spacer is different.
Sent from my SM-G988U using Tapatalk
He wasn't talking about the F Superduty trucks (F450s). He was talking about the 99+ Super Duty line of trucks which were the heavy F250 and the F350 (+). The ZF6 is not a direct bolt on to our IDIs. I don't what all is different. The only real benefit to the ZF6 is that it has a granny first gear. The rest are all similar to the ones in our ZF5s. IIRC, the shifter for a ZF6 even listed the lowest gear as "L", not "1". A ZF5 from behind a 7.3 PSD will work with our IDIs too.Rock you sure about the SD being different? The back end of a 6.9 or 7.3 are all the same . Whcih would mean the trans bellhousing is the same. It would be odd for the SD to be different.
