zukinut
I know this has been beaten to death. Ive read that a wastegate has less turbo lag off the line but can cause higher egt's and such at higher rpms. Whereas a non wastegate can produce good power thru the rpm band but has some lag off the line.
Still not sure which i should go with. My truck has one purpose. It pullls my 4000lb samurai rockcrawler to different parks. Some parks are an easy drive on flat highway and some have 8-9% 3 mile long grades. It does fine without a turbo on the flat stuff. Altho with the 4.10 gears and the zf-5 the mileage is nothing to brag about. I just want to know whats best for the long grades, my truck sees 3200rpms in 3rd doing 45 mph at the top of the steepest longest hill i encounter. I want to be able to do that 45-50mph at a lower rpm.
I will be running a moose pump as soon as i get the turbo.
Thanks in advance.
Will
Thanks in advance.
Will
A wastegated jobby will definitely help with the smoke control. Your going to lay some coal with the non-wastegated. Perhaps this will help you decide.
