As far as I know is a 4.10 with open gear that is what the owners manual said that little code means, do I still need the limited slip additive?
Look on the bottom line of the driver's side door sticker for your axle code then check THIS CHART to determine if you have limited slip.
Maybe whoever orderd the truck brand new planed on driving around alot of corners and not so much off-roading.
