where to get a Complete 7.3 gasket set
Probably the best place is international parts counter. Thats what they supposed to use from the factory so I'm told. I do not know this for a fact so check around before you buy. What ever you buy just make sure you do not install an oil pan gasket because they will leak. Then you will have to pull the engine again to repair it. The factory used an RTV sealant. I use permatex ultra copper plus. It has never failed me after more years than I like to remember. Spray Hilomar on the head gaskets will make for a great sealed surface too. Three lite spray coats is all you need.
lbzbuick
diesel =)
illinois
I also heard that carquest sells the victor reinz gasket set too but I dont know that for a fact either
hesutton
The Anti-Anderson
Bowling Green, KY
Reliant Gasket on eBay has the kits and at a better price than I've found at CarQuest or other local stores. Plus, they did have a great price on valley pans as well.
Heath
cowboytueller
Reno, NV
Northern auto parts catalog also has one along with the engine rebuild kit too if you want one.
SixFourShanks08
