TWeatherford
I just bought a set of what I think are factory wheels for my 97. They have around a 5.4" offset which is what my research has led me to believe the cab and chassis trucks came with, and is the largest offset available in factory wheels. They appear to be hub centric, I put two on my rear axle for fitment and the inside one was a little hard to get off - definitely a snug fit. However, they also appear to be set up for lug centric as well - see the picture.
The lugnuts in this picture look to be really strong. Will they work with these wheels? I can't just take a lugnut off this truck - its not mine.
Finally, the Dana 60 has a horizontal shock on it, but my 94 doesn't. But my 94 has a big wierd looking bar thing that I have never understood the purpose of. So, is this thing necessary on my 97? I see where the brackets are for one, but its missing. If you've been reading my build thread you'll see what I'm not at all surprised to find missing parts on this truck.
There is another eye on the 97 that isn't on the 94, I don't know what it might be for. I circled it and the end of the shock.
There are only 4 leaf springs and an overload on my 97. My 94 has 5 and an overload. I would expect the dually to have more. With the flatbed its already sitting slightly on the overloads. I don't figure this is a problem, as it will make for better ride, and if I start hauling heavy I can always do airbags or get a stouter spring pack.
Finally, the axle to lift block adapter/spacer thing on the 97 is welded on. It doesn't appear to be welded on my 94 or my 85 pickup trailer. Are they attached in any way, or is there any good reason it would be welded?
