Wheel knock
squoril
United States
Just noticed the last few days when I make a sharp turn. I get a knocking from the front left side of the truck that is proportional to the speed. Its not very loud and I would guess it knocks once per tire rotation.
It goes away randomly and comes back when you tuns sometimes.
I also noticed when I brake it shuts up tell I let off
1990 f250 xlt lariat, hubs unlocked
Sent from my XT1049 using Tapatalk
squoril
United States
Nope, its my grandmas old ranch truck, I just got it so I've been slowly going through it inspecting everything and doing maintenance (unstick parking brake, highbeams, oil change, coolant change {yes have scas}, Lucas fuel additive, air filter, new belts)
Still on the list as money becomes available to spend-
Injectors and pump
Rear tires
Fuel filter
Pyrometer (for tuning)
Digital Coolant temp meter (because I like data)
Bypass coolant filter
Remove AC system
I need to get some shop manuals and read up on the drive train so I can inspect and service it, looking at ujoints and diff fluid.
Currently the van is in the shop so the truck is my daily driver
How dangerous is the knock?
Will need to take a 200 mi trip over the mountains for the 4th
Will the need replaced or just cleaned out and repacked?
Can30Diesel
Agassiz BC
I'd test for play in the tire and see what you get. Take the vehicle weight off that tire and try to wiggle it left to right, up and down, give it a few spins and listen for rumbly sounds. It should be silent and have no play up and down or left and right. Of you get movement, or hear a rumble, its time to take a look at the wheel bearings. What you find in there will answer the question of what needs to be done. Usually its just a cleaning and repack. You will need a special socket to remove the nuts and retorquing them properly is very important.
If it was me, I would make sure thats squared away before any long trips.
squoril
United States
Im supposed to leave on the trip in 10 hours, upon inspection i cant tell if the bearings are worn because the upper ball joints have a LOT of play in them.
can i just tighten them down or do they need to be replaced?
do i get the $15 special from knects or do i need to get a specific brand?
ill be monitoring this thread all day so quick responses would be appreciated
squoril
United States
Grabbed the lifetime ones at auto zone Pulling everything apart now
Did you pick up a hub nut tool?
I would clean and repack the wheel bearings while in there.
Mobil 1 synthetic is some good stuff.
Sent from my SM-G900R4 using Tapatalk
squoril
United States
Haven't learned about that yet still pulling the hublock
squoril
United States
ok i see where i need that tool, looking for one now, any idea where i can get one in the next hour?
squoril
United States
Yup, starting to make sense now, just got a d70 socket from auto zone, now I know what to ask for :p girlfriend ended up being able to go with so were taking her car I'll finish this up sunday
Thanks for all your help
brb5
