What type of rotor do I have on my truck?!?
GaPchNCrm
Franklin Ga
OK so I start hearing that lovely grinding noise thats screaming " hey! you have a cracked rotor!" :rolleyes: I go to the local parts store ( technicaly a Bumper to Bumper), get the front rotors for a DRW 93 F350 2WD. Last I checked that IS what I drive, right? :confused: So we get the tire off and the rotor on my truck is attached to the hub. Its one whole unit. Took it to advance and autozone and they both said " not anything we carry." Soooooo.....
1. What exactly am I looking for here? I'll post pics of whats on it in a few. and
2. WHY is my truck different from the rest of the 93 F350 2WD DRW's out there? :dunno
HELP!!!!!!!!:yell:
dwaymar
dwaymar
GoldenValley AZ.
shoul br a pressed fit had one like it got rid of it last year knock the studs out and then it should come out with a little bigger hammer
luc to ya
BROWNIEBOY525
The old fleet
south jersey
you take the whole hub off then you have to knock out the wheel studs and the rotor will come right off. i think they were like 60 each.
Tanya, sorry I didn't get your message until this morning. If you still need to speak give a call. I think you got your answer.
Sounds to me like the parts guys need to find another thing they call a JOB....:D
diesel4me2
Camping is more importanter!
northern illinois
mine has an extension/hub that bolts to the rotor. pull the hub, on the backside of the rotor/hub, unbolt the extension/hub (studs are pressed into the front of extension/hub) install new rotor, tighten and install. wheel bearing torque for my 86' is 20 to 25 lbs and back off 1/8 turn.
don't know if it's a dually thing or not with the extension.:dunno
chris
