Both of my rigs build pressure while at normal operating temps. The rad hoses are hard. It's normal.
4 PSI is not
Have you confirmed H2O Pump Rotation? New Cap?
It might be worth putting some die into it, running it a bit, and checking the oil to see if it's migrating.
Well, I haven't started to tear into it just yet. I'm going to give it one more run just to be sure.
I have taken it on several runs that were more than just a "jaunt" I've had in the back of my mind the "Ford" break in procedure, and I've been trying to accomplish that. It involves driving the rig gently to a place where you can get it going to 30mph and then tromp it and accelerate to 50mph full throttle, and then decelerate to 30 about 10 times... So, the area I've chosen is about 2 miles from my home, and you'd think by the time I drove over there, and ran it back and forth, and then drove home again, it'd be up to temp for sure. The dash gauge(I know, I know,) reads at the "O" in normal.
Oil is clear. Used 2 different caps, one a 7psi, the other a 13psi release type. They both seem to work correctly. When the rad is cool, I fill it up, and the overflow to the "low" line. Run the truck, and it pushes coolant out into the overflow, it goes up about 2 inches(twice as much as my '86) and then bubbles constantly. When I leave it to cool, it pulls coolant back in, but the rad retains air at the top, and the overflow goes down, but still about 1" above the low line. If I siphon the excess out of the overflow, and put it back into the rad, it just tops it off exactly, so it looks like there's no coolant actually missing, and the oil is spotlessly clean.
I'm going to try the clear hose on the passenger head and see if there's any bubbles coming from that side, that should confirm it...
The pump appears to be rotating the right direction, but, I can't actually see any flow visually through the top of the rad with the cap off, even when it's down a bit. I seem to recall that usually, when it's up to temp, you can see a bit of flow splashing and swirling in the rad?!
I'll confirm this this morning when I take it for a final run.
Zigg
