sle2115
NRA LIFE MEMBER
Well, I thought I had burped it all out, but I just did another run, and when I came home, it wasn't bubbling at all. (***?)
So once it cooled a bit, I pulled the rad cap, and it looked like the coolant is down a bit. so I filled it up, and then levelled off the overflow, and sealed it all up. I wasn't able to do any more runs today, so I just left it at that.
Checked the oil, and it's not up, and no drips anywhere, so I'm hoping that it's just releasing air, and the coolant is replacing it, and it'll eventually settle down.
Good signs Zigg. I hope it all works out for you. I can tell you that mine kept getting a little low on coolant for several runs after I flushed it out and put the new water pump and coolant in there. Must be little pockets of air all over in there. Coolant never went down much, and has finally stopped, but I had the same fears as you.
Oh, and I had one of those cavaliers as well. We even lifted just the front end on the racks anytime we touched the cooling system on one at the shop! Then we got the vacuum deal that took care of it. The problem with them was the cooling jacket was higher than the radiator, so the air just hung out there. There was another easy fix as well if you were doing a thermostat, and is something I do to all of them these days, which was to drill a small hole in the thermostat flange so air could get through.
Good luck,
Scott
