I tried one last attempt today. To confirm that I was actually pressurizing the cylinders accurately, I pulled the valve cover on the Drivers' side, and undid all the rockers, so all the valves will remain closed on that side.
I re-did the leakdown test on each cylinder. Interesting results.
I mounted a hose in the hole for the glowplug controller at the back of the head so the top of the hose was 6" higher than the rad. Let the pressure equalize completely, filled the rad right exactly to top, rad cap securely on, marked the level of coolant in the hose, and left the top of the hose open so that air could escape, and any pressure in the coolant would push the level up in the hose.
Shop air (100psi) to each cylinder via glowplug hole one at a time.
#2, pushed coolant up the hose about 1" in 5 minutes.!!
#4, pushed coolant up the hose about 3" in 5 minutes.!!
#8, pushed coolant up the hose about 1" in 5 minutes.!!
#6, no coolant rise at all in the hose after 10 minutes!!
I did each cylinder twice to be sure.
If my knowledge is correct, there should not ever be any rise in coolant pressure when the cylinder is pressurized. There shouldn't be any connection between the two!
Does this mean I don't have 1 crack somewhere, but 3?!!
It started to pour at that point, so I had to abandon ship, but I plan to do all those on the passenger side again just the same way, for comparison, and to rule out the passenger head.
I'll post results as they come in...
Finally, something is starting to make some sense, even if it still doesn't look good...
Zigg
