mrbrink
I decided to swap out the non working factory ford radio for a cd player in my 85 3/4 ton the other day, and now I've got electrical problems. Since I installed it, my dash lights haven't worked. It blew the fuse, and as soon as I put a new one in and hit the switch the fuse blows. I didn't change any wires, I simply spliced in the new harness using a 12 volt test light to figure out constant and ignition and thats it, I didn't touch any wires that weren't part of the factory radio. Does anyone have thoughts on this or where to start looking for the short?
Also, the radio worked fine for a couple days, and now its like it isn't getting enough power. low volume it works fine, but as soon as I turn it up it'll turn off and on until I turn the volume down. Same deal if I put a CD in it, and I swapped the head unit for another one I had and the same thing happened. I'm thinking not enough power going to it but I'm at a loss with this whole thing.
Thank you in advance,
