CH302K
1993 f350 7.3 idi. I have replaced the radiator and water pump and still over heating.Does the 7.3 have a thermostst and where is it?
thanks
thanks
thanks
I'd suggest two things...
First Purchase
An actual FORD Motorcraft thermostat or an International Thermostat...those are the only two you should use WHAT SO EVER
Here is a Tutorial I did on this subject take a look
http://www.oilburners.net/forums/sh...T-REPLACEMENT-101-Tech-PicTutorial&highlight=
Hope this helps you out!
Al
I don't know why everyone says to only use a ford or motorcraft thermostat. I used a thermostat from napa 3 years ago and it is still in working condition to this day. (185 degree thermostat)
open...should be IIRC 192 begins open fully by 210 FYI
I knew powerstroke had to be at 205 degree, but that 210 thermostat sounds like it should be on a chevy, not international.
OPENING begins at 192 IIRC and fully open by 210....as previously mentioned...
I never meant to come off across that the other thermostats were bad, I was just saying I've had luck with the stat I've been using.
You say clamped? Is it inside a housing like a gas truck?
