Wallowed out drive shaft hub bolt holes.
ironworker40
NYC Ironworker
nj
Some axles have wedges that go on bolts to lock axle in. Its been years so I have no idea of what sizes they are available in but you could easily taper hole on axle to use them if you can find the correct size.
http://www.quad4x4.com/qu40577.html
These say dana 60 and 7/16
rwk
S.W. mich
strange, 12 mm is .472 so a bolt would be slightly under that a couple thou, but dont think .454.
I might have measured where the bolt was worn a little, but a 12-1.75 mm thread die just fits fine on them, I know it's not a 7/16" bolt, I couldn't even start the bolt in a 7/16" thread die.
I think I'll be just fine with new bolts, all the old bolts are worn where they fit thru the hub. Not as bad as I first thought, gotta learn not to panic in my old age.:D
Thanks Fastenal. Hey do you guys stock the 12-1.75 mm bolts and lock washers? Sure do, they come in a box of 13 or 25.
So I bought the BAGS of 25 of bolts and washers. Total cost $21.15.
Just gonna replace both sides rear wheels for good measure, cheap enough. Yep, there grade 8 Made in USA.
READ MY STORY IN THE LOUNGE ABOUT GOING TO FASTENAL, interesting. Gonna take 1/2 hr to type it in.
