That's a synthetic blend, it may not need it. Try without, if it chatters, you'll need to draw a few ounces out and add the LS additive, no harm done. Most full synthetics don't need the additive.
I had a leak in the rear end when I bought the truck. Thought it was the pinion seal. Took it to a local rear end shop it ended up being the pin on the shaft to line up the yoke. They cleaned it up and put it back together and no leak.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
