valvoline DuraBlend gear oil 80w90
gatorman21218
Ashland VA
I bought some today and the guy told me i didnt need any friction LS additives. Is he right? Would it hurt to add some anyway?
RLDSL
Diesel fuel abuser
Arkansas
That's a synthetic blend, it may not need it. Try without, if it chatters, you'll need to draw a few ounces out and add the LS additive, no harm done. Most full synthetics don't need the additive.
gatorman21218
Ashland VA
Thanks. I still need to figure out why my rear is leaking though. once i fix that ill change the oil
Mulochico
Modesto, Ca
I had a leak in the rear end when I bought the truck. Thought it was the pinion seal. Took it to a local rear end shop it ended up being the pin on the shaft to line up the yoke. They cleaned it up and put it back together and no leak.
Bradz
