LUCKY_LARUE60
why can't a valley pan be resused ?????????????????????????????
Jim,
The "book" says "NO".
If you go against "The Book", how bad will you feel if you have to replace it later, as oppoosed to how good you will feel if it works?
Its a risk versus rewards problem that only you can answer for you.
Michael,
I know what you are saying, it's just I have the valley pan and it looks so good, what is the worst can happen on a diesel? Sucking a little air from around the intake, now it was a gasoline engine then I would say a big NO. If I "were" to reuse it I would use a sealer BUT I doubt if I do reuse it.
Jim
Well, I read your sig and it says "soon to be turboed" a used one may hold up fine N/A but I would think you would be risking loosing some boost once you have it turboed. Just my .02
