Freight_Train
Traitor to the brotherhood
Ummm,Ok,So I get everything wrapped up and go to turn down the fuel(yea,back it off.Don't want to stress this temp engine too much) and I can't turn the fuel screw.I have the IP on the work bench,used a cheater bar on the allen wrench but it just flexes/twist without moving the screw.I am afraid to pull too hard.Heck,when I turned it up I only got 3 flats of movement.I know it can't be bottomed out.Also,when going to install the turbo I found out that the Factory pedistal has an itty bitty drain end but the Valley Pan/intake gasket has a really big hole......Is there 2 gaskets?one for NA and one for turbo?
