TVRV...adjustment/testing ?
HammerDown
Glenolden Pa
Anyone know what the reason the throttle needs to be 0.515 or some 1/2" from wide open during part of this test?
(I suspect a bad Trans Vacuum Regulator Valve) $89.00 from Father Ford:(
Guess this is a dealer only item...eh?
Also, when checking vacuum at the vacuume pump what #'s should I see at Idle?
Also, what happened to TDS Forum? I've got PM's I can't get to?
Thanks...
HammerDown
Glenolden Pa
Ok, so I tested my (Trans Vacuum Regulator Valve)...I wasn't able to perform the test because the unit itself WON'T hold vacuum. The things JUNK :rolleyes:
New one will be here tomorrow from my local dealer.
I suspect this as the sole cause my tranny (sometimes) doesn't like to shift from 1st to 2nd unless I come off the throttle some, then BANG!
Vacuum pump itself is strong with some +25" of vacuum.
*Observation...as per test procedure states, one should hold the throttle 1/2" from wide open.
I noticed when operating the throttle by hand there is a noticable (resistance/stop) exactly at that point before WOT.
Stay tuned for more. :drunk:
OldiesF250
dedicated....
St.Charles, MO
mine was busted and i went to a junkyard and got one off a truck with bad headgaskets for $10. now my truck will shift anywhere from 1500-2300 rpm depending on the throttle of course.
Lance
