Alright, just a re-cap at this point, but I have not gotten anywhere with my missing parts, but it isn't like I've been searching high and low either...
Basically I'm missing what bolts to the y-pipe (cross-over) that connects the y-pipe to the passenger side manifold and also to the up-pipe (that has the pedestal mount for the turbo). I am not certain what the part is that I circled, it looks like an elbow -
Please correct me if I'm wrong-
I don't think I need an oil line as my turbo already has a line on it, but a flexible steel line would be an upgrade - I could put a T fitting on it and an oil pressure gauge to monitor the turbo as well.
I don't need the different valve covers as I plan on venting the crankcase gasses to a catch can, I don't need to coat my intake and possibly damage the rear cylinders with extra oil/fuel... I can do this correct? I know modern EFI engines will run lean if the PCV system isn't vented back in (as the ECU is expecting that airflow), will the diesel care?
I just got around to setting up a push button glow plug controller as I've got all new MotoCraft plugs and I don't want a ****** controller to kill them. I've still got a rebuilt IP and new BB code injectors to install.
I wanting to turn up my current pump as this truck is SLOW, but without a pyro I don't want to damage anything. If I'm WOT and banging gears with a load I will get an ever so slight haze out of the exhaust - can I safely turn the pump up one flat without worry? By the looks of it, it's the original IP and injectors, so she is tired...
