Turbo removal for injection pump replacement
Ray-F250
Georgia
guys do I have to remove my turbo to replace the injection pump and injectors
Thewespaul
Bulverde, Texas
You do not for the factory turbo setups. Remove the intake, throttle bracket and leave all the lines connected to the pump. You will be able to snake it out with some finesse. You can remove the lines for an easier removal.
Sometimes a liberal amount of four letter words help you feel a little bit better. I don't like to remove the lines from the pump until it's all out of the truck. That way I can remove them one side at a time. This will reduce the chances of putting the lines back wrong. To me, it's just easier that way.
I do. it can be a royal pita to remove for some of you folk
, but I have modded my cowl to make turbo removal a 10 minute job if I have all the tools laid out
