a little info on the truck would be good as well.fill out your signature
the whicked wheel is a waste of money for any ford.all it is is the factory stock compressor wheel for the 94.5-97 PSDs and sold as an overpriced upgrade for the 99-03 7.3
ball bearing turbo is worth it.as the stocker can only handle around 26PSI safely without killing it.
a different ratio housing will bring the boost up quicker with hotter EGTs.you can get the turbo to spool faster by adding more fuel with the use of a chip.
and remember no matter what you do you will only see a 75 max horsepower increase untill you upgrade injectors
