Grass Hauler
Hi guys my factory IDI turbo has an oil leak coming from where the oil feed line goes into the T fitting that feeds the turbo. It is not leaking where the threads go into the T fitting but out the back of the nut/collar causing oil to run down the line and settle on top of the intake. This happened after taking it apart, I feel it is plenty tight in the T and is not leaking at the connection. What can be done with the line to get it to stop leaking, can it be fixed without replacing it? Since there seams to be no turbo replacement parts available. Thanks for the help
Note picture was from another persons post I just wanted to illustrate what I was trying to explain.
