turbo heat shields
ironworker40
NYC Ironworker
nj
Does anyone have a picture of a ats 093 turbo with the correct heat shielding that came with it for the firewall, evaporator box, etc. I want to re-do mine and would like to know what is supposed to be there. Also were can it be purchased?
vandy7.3
wardsville, missouri
Ats no longer makes parts for these turbo systems. So unless you have all of that stuff you may be SOL. I have most all of the factory heat shields they are a little bent up but I didn't use them when I put the turbo on my truck. I just exhaust wrapped everything and bought a turbo blanket off eBay.
Sent from my SCH-R890 using Tapatalk
ironworker40
NYC Ironworker
nj
Mine only has 1 piece of heat shielding behind the pipes against the firewall. No blanket on turbo. nothing on heater box I wanted to see what they came with so I can replace what if anything is missing
vandy7.3
I cut more insulation off my truck than I put on when I installed my turbo. It's an xlt lariat, the entire fire wall had insulation had to get rid of it all to fit up pipe and down pipe. But I did wrap all my exhaust components. Should be good enough
Honestly, you will be fine if you don't wrap anything.
jaluhn83
Upper Marlboro, MD
I got something like this:
http://www.ebay.com/itm/Thermo-Tec-...Parts_Accessories&hash=item3a81d51a4d&vxp=mtr
but a cheaper knock off - can't find it in the 30 seconds of searching but it's the same idea.
I used it to wrap the up&down pipes and turbo hot side. You may not need it, but I like the idea of having some insulation there. It can hold moisture though and accelerate rusting though if you're somewhere that's an issue.
kendawg69a
prov,ri
Have a 94 stock turbo I could snap picks of for u if you want?
Sent from my SCH-I605 using Tapatalk
Staff online
