truck will not start not geting fuel. what fuses is there for the pump? we checked the pump and it is working and we ran a wire from the bettery to the hot side of the pump and it started any ideas?? thank u
During lunch hour and no replies? Well, don't know about the fuses, I take it you checked that the wire to the FSS is definitely not getting power, so I would look at the ignition switch. You could rig up a toggle for power to the FSS until you determine the cause. I am dumb, hopefully a smart person will chime in...
How do you know your not getting fuel? Are you getting fuel after the fuel pump? If not bad fuel pump possibly. No fuel after the Filter? Clogged filter. No fuel out of injector Pump? FSS not clicking on or something else.
Stars at the end where you are having trouble and work your way back with a test light. That would mean check the first connector back from where the wire attaches to the pump. Continue from there if their is still no voltage to that wire.
thanks guys i will try the ignition switch out. I know its geting fuel cuz i put a hot wire on the pump and **** a line off the injector and diesel came out so thats not the problem.I drove it home with a hot wire on the pump cuz it wouldnt start at the fair yea that was real nice with a date ready to leave and the truck wouldnt start . The problem is the pump isnt geting any power thats why i was woundering if there was a fuse if not is the wire hard to replace if the ignition switch dosent work? thank u all for the info
