Sad to say I'm getting used to it. This time I was on the highway and the moment I switched tanks it died. I flipped it back to the other tank but to no avail. Both tanks were full, the forward one of bio-diesel the other of clean filtered motor oil. Thing shut off like a switch. I got it off to the side and towed it home.
Its got 12.85 volts at the batteries, Carter lift pump is working fine, fuel is flowing to the IP, and I checked the shut off solenoid, which seems to be working fine. Although I did not open up the IP and visually inspect the linkages. I also checked the wires going to the IP shut off, also fine. Although I am curious why, if both carry a full 12v why they are two different size spade connectors ?
So I guess the question for today is, what if any other electric components might be interfering with the operation of the IP.
The truck started fine, ran fine, and went off like a switch. No choking or sputtering at all. Seems electrical, but I'm not sure if there's anything but the fuel shut off solenoid that could be the problem. Unless that is something broke inside the ( supposed to be fresh rebuilt ) IP
Any ideas ? cause other than change the IP I'm not sure what might be wrong with it.
Thanks
Dan
Thanks
Dan
