I'm having some memory problems. What is the tps setting at idle? I know the low side is .96 volts but the high side has me thinking its either 1.2 or 1.02 volts at idle. I just finished a long heavy haul (about 5000 lbs of trailer and horses) and my trans temp reached 195 degrees. Yes, thats my new BTS trans doing that. The outside temp was right at 100 degrees so that plays into it also. I'm just not really happy with these findings on the freeways and surface streets even unloaded. The temp slowly increases to the 195 point. The level of fluid shows I'm overfull by about 4 inches if thats possible. I know when I filled it I did exactly what BTS told me to do. Then after some time I added the Mag Hitec pan. It requires an extra 2 gallons to come up to the full mark. The dip stick shows this high level whether the motor is running or shut down. I thought maybe it was splashing that far up the stick. I may just have to drain it and see how far down the stick dips into the pan. Thanks all.
