Seriously need some help, driving myself nuts
mccumbersdylan
Ohio
(1991 f350 automatic 4x4 ) checked the TPS, I was told there would be 1.2 v at middle wire at idle but I'm getting less than .2! And at wide open it read .34! So I pulled the connection at the pcm and checked the continuity and it is good.So based on no tach, OD light on, no voltage to TPS, and couldn't get code reader to communicate with the obd1 does that mean the pcm is bad?
could there be a short to ground somewhere that I cant visually see? If so how do I find it (there were mice in this truck at one point)
Clb
Another old truck
nannyfornia
1 post wonders
I refer you to the search button
onetonjohn
California
From google AI:
Yes, based on the multiple concurrent symptoms, it is highly likely that the PCM (Powertrain Control Module) is bad. The fact that you have no voltage reference to the TPS, no tachometer, the OD light is on, and the OBD1 code reader cannot communicate with the computer all point towards a central failure in the PCM or its main power/ground supply.
Sited evidence:
No 5-Volt Reference Voltage to the TPS: The PCM is responsible for supplying a consistent 5-volt reference signal to sensors like the TPS. The extremely low readings (<0.2V) you are getting, even after confirming good continuity in the wiring from the TPS to the PCM, indicate the PCM is not outputting the correct voltage.
No Communication with the OBD1 Reader: The inability of the diagnostic tool to communicate with the computer is a classic sign of internal PCM failure or a loss of power/ground to the module itself.
Multiple Unrelated System Failures: The PCM controls both engine and transmission functions (engine timing, fuel injection, shift points, etc.). Failures across multiple systems at once (tachometer, overdrive light, TPS, diagnostics) strongly suggest a core computer problem rather than separate individual sensor or wiring issues.
Flashing Overdrive (OD) Light and No Tach: These symptoms are often related to transmission control issues, which are managed by the PCM.
Just wanted to see what AI said. Search here might be more reliable information.
onetonjohn
California
Crud. It asked if I wanted to know how to test it and gave me instructions to walk me though the procedure. It's kinda creepy how good it is. I have had it give me the wrong answer at times, to take it with a grain of salt and double check with posts here - this place is the best place I've found for information.
Just in case HAL gets creative....
HAL can't get very creative unless there's electronics involved. Just like the scene in Terminator 3 where the gal takes over all of the police vehicles. She could control the engines, maybe even the accelerators, but not the gear shifters or the steering.
DirtyWood
Earth
I'm sorry Dave. I'm afraid I can't do that.
I know I’ve made some very poor decisions recently, but I can give you
my complete assurance that my work will be back to normal.
Daisy, daisy, give me your answer true. . .
At least that problem was resolved 9 years later! SAL didn't seem to have any of his issues since they made it to Jupiter and back.
