high psi
I'm not trying to argue.
But, From everything I've read about the so called 'Torque Screw' (which it's NOT) is that is has no effect above 1100 RPM or so. It's simply there for emissions. It was added for the 93 IDIT in order for the truck to pass the 'Snap Test'
The Turbo will not spool/boost enough to burn the added fuel at low RPM's. It's there to trim the lower RPM fuel, and still allow max delivery at higher RPM.
The theory You've described goes against everything I've read.
Go Here and read the OPTIONS list at the bottom of the page. http://www.stanadyne.com/view.php?id=40
"•Low Speed Fuel Limiter (smoke and emissions reduction) "
The biggest problem with these rigs is they won't build boost until 1500 RPM's+
So there's no sense in trying to inject more fuel before the boost comes up.
Here's a common situation with the IDIT. Loaded with a good load You come to a hill. Your starting to loose some speed, so You hit the throttle a little. As the truck slows, RPM's drop. Once You get to 1300-1400 RPM's the coal is rolling and EGT's are climbing. Then it's time to downshift. (You've gotta be able to BURN that fuel. If You keep pouring fuel down 'er, She just keeps getting hotter)
Now that You've down shifted, the EGT's are still up there (from the over fueling at low RPM) The EGT's will come down, once the engine can BURN all of the fuel.
My theory is: Why fight the elevated EGT's, by over fueling at low RPM's?
The page you referenced is the newer stuff. It's a torque screw. I know I'm kinda an unknown on here, but I know a little something about these pumps and they're still old technology. The amount of overfuel is minimal (talking like 1-2% if memory serves), it's just enough to kick the rpm's back up when there's a load applied to the engine. It's not some kind of massive overfuel, nor does it keep climbing as the rpm's keep dropping. once you've dropped the few hundred rpm it takes to hit the max fuel delivery it stops climbing and the rpm's keep dropping if the load is too much or increases more. I could see the torque screw helping with the snap test since with no load to pull the rpm's down, as in a snap test, the torque screw will cut the fuel back from the max setting. It's only when a load causes the rpm's to drop that it'll fuel up.
