Goofyexponent
Mentally Unstable..
I decided I would try and play with my torque screw this morning. I also set my pump up another .5 of a flat as I had NO smoke, and I am hooking my pyro up this weekend.
I turned the screw all the way in, and it severly limited the fuel at lower RPMs (1800 and lower) but once it climbed to about 2000 RPM it was like someone turned a switch on. The truck took off like it was kicked in the ass for peeping in the girls locker room. I know the screw controls the fuel curve at a lower RPM to limit smoke.
The screw must have to be retracted to gain fuel at lower RPM's. I didn't wanna do any damage, so I returned the screw to where I found it and walked away.
How does this so called torque screw work? Is it supposed to deliver more fuel when retracted or threaded all the way in?
