Thermostat housing seal
Cubey
Van dweller
Do y’all think I could have a blown head gasket and it’s over pressuring the cooling system and that’s the weak point? I have had to replace radiator a couple times.
Look for bubbles in the overflow. That's the weakest point for air to escape.
The only time that I've had an issue with this sealing was when I accidentally had a thermostat slip out of place and part of the metal "flange" was sitting out of it's groove. On things like this, I like to use RTV on both sides of the gasket. It makes it easier to clean up the surfaces the next time you have to replace it. The gaskets really like to stick themselves down.
ifrythings
BC
I have motorcraft thermostat in it. It’s all I’ve ever run. I have inspected the housing well and cleaning the hell out of the flange. It always leaks at the lower bolt.
By any chance is it the bolt hole leaking and not the housing? It’s been a while since I did a t-stat on one of these engines but maybe someone put to long of a bolt in at one time and made the blind hole a through hole into the cooling system? Mite just need to put some thread sealer on that bolt?
hadley000
Upstate NY
I had this problem too. Check the recessed area in the block where the t-stat sits and make sure there isn't any rust or debris in it. It's a snug but not tight fit. It had a bit of corrosion where the outside of the t-stat sits and I didn't clean it out good enough. It must've not let the housing seat fully.
The Right Stuff is great sealant and should work well.
Slicknik
Burbank, CA
You don’t have a blown headgasket,
if you take the rubber off the thermostat then it will seal ( go buy the oem motorcraft replacement)
but since it’s not motorcraft it will fail eventually and you’ll be swapping it again , (took mine out in the middle of a road trip cuz it failed )
if you use s sealer , you run the risk of getting it in your coolant and then you get to flush it out which is a headache you don’t need
tke395
