well i dont know how i did it but on the cab swap i am doing i used a 93 gas cab and 94 automatic diesel wireing on an 88 F350 with a 5 speed.i dont know how i managed to do it but the speedo is working
.dont know if its right or not but atleast it works.i can reprogram the PSOM later if needed.i dont remember it haveing a sensor in the rear end though but it does have rear abs so it might have it.
now i also swapped in an f450 hydroboost set up.the brakes sucked to begin with.but now they seem to work good except that if you go to do a panic type stop the pedal goes straight to the floor and all of a sudden locks all 4 wheels up.if you hit it normally it stops fine but feels like there is no pressure in the brake system.is this normal for the hydroboost/f350 master cylinder combo?if not what should i be looking at?
![Really ;Really ;Really](/styles/default/xenforo/smilies/Really.gif)
