Wiring problems after a fire
1mouse3
il
You are giving the sense wire with the bulb a false reading, these two 6ga wire need fixed and ran to there original home. You have the yellow power lead to the fuse/breaker/relay box on the drives fender looking all jacked up, if as suspect there is low voltage on that box and in turn giving you the wrong output.
michwalt15
ga
- Check voltage with the ground lead on the case of the alternator and positive test lead on the positive of the battery.
13.0 volts
- Check voltage with the ground lead on the case of the alternator and positive test lead on the positive of the alternator.
13.0 volts
- Check voltage with the ground lead on the case of the alternator and positive test lead on the y/w wire pin of the alternator pigtail unpluged, also have a grounded test light hooked up to the y/w wire pin at the same time testing to give load on this lead.
0 volts
- Check voltage with the ground lead on the ground post of the battery and positive test lead on the positive of the alternator.
13.0 volts
- Check voltage with the ground lead on the ground post of the battery and positive test lead on the positive of the battery.
13.0 volts
All of this was done with the engine off.
michwalt15
ga
I will fix the cable on the left running to the solenoid. I don't know where the alternator cable, on the right, goes to the fuse box. There's not another big wire that runs to the fuse box that it should connect to.
1mouse3
il
I was rembering wrong where the alternator wire went originally before I changed it. Went digging through old photos and see it was supposed to the starter relay with a fusible link, ignore the second yellow wire I have going to the glow plugs at the time. The alternator and fuse panel wire would be the two on the front relay, split too two special brown wire that are fusible on the end.
1mouse3
il
0 volts
This should be the same 13v as the rest you tested, where do you have this ran? Just run this to the positive post of the alternator, if you cant find it in the harness.
The "A" terminal is the one that the alternator/regulator uses to determine the alternator output. If this wire does not have 12v on it, then the alternator/regulator will try to jack the output up trying to get that "A" wire to 14.5 volts. Once the alternator/regulator "A" wire has 14.5 volts on it, it will trim the alternator output down.
michwalt15
ga
I will try this tomorrow. thanks
michwalt15
ga
I will mess with it tomorrow. thanks.
michwalt15
ga
I checked the voltage at the box on the drivers fender. It is the same as the battery 13.1. The truck was in an accident before I got it, thats why the box is all jacked up and sitting in a tuperware dish.
I moved the sensing wire lead and the 6 gauge wire to the relay, but its still overcharging.
1mouse3
il
Thank for the corection on the sense wire.
So there is not much issue to the fuse panel then for now, if gots the same 13v of the battery but that damage section of that 6ga wire looks like something that will corrode out giving issues.
This Is what you need to fix that wire and if you also extend the 6ga off the alternator, to be ran to the relay as well following the a/c line to the core support. This would let you bundle the wires off the engine into one harness and clean up mess.
0 volts
Did you solve this loss of voltage for the y/w wire?
michwalt15
ga
I fixed the yellow wire coming out of the loom and the black/orange charge wire but it's still overcharging.
I don't know where to start with the y/w wire.
1mouse3
il
Just put a ring terminal on it and put it on the positive post of the alternator, that has the black and yellow stipe wire on it.
michwalt15
ga
Now I need a wiring diagram that shows the tach with color coded wires. I've found several different diagrams but they all go by pin order and not wire color.
Here's a diagram. Hard to make out that one color on the tach sensor. Is it a tan/yellow and a darkgreen?
  • WD_Ford_183883.pdf
