Bart F-350
Hello,
I bought my truck in 2005, due to registration issues I was'nt allowed to drive her.
In order to keep everything moving and not rotten in place I took a tour trough the remote woods every month.
A good week ago I started a bigger tour, the mileage was 8000, and the tanks were full.
the weather was cold, around 0*C, and dry. You could notice that the whole truck was a bitt stiff from this long rest, but everything went well, better be, because I had done quiet some things for preparations; rear axle seals replaced, since the axle oil contaminated the brakes, also replacing the axle oil and brake linings and cilinder.
In the front I replaced the brake hoses due to old age, and overhauled the calipers and MC. after a check of all the oil levels I took off.
al in all I drove a 1600 Miles, and even at the halfway mark you could already notice that everything started to free up, starts were easier, braking improved, shifting from the E4OD also.
there were of course a couple of small flows: after a couple of miles the engine started to smell after diesel, and after a quick check I'd seen that the new fuel return lines were sweating, I decided to put them under surveillance.
Also I noticed that at about 60 miles at 2000 rpm the E4OD started to hunt, once and a while, about 200 rpm plus, and then back again at 2000 rpm???
anybody here an Idea about the cause?
What would be the Ideal charge for the batteries? The gauge indicates 13.2V I alwais thought 14.2 would be best?
This was a very awarding trip, I got the truck trough and through warmed up (and now ready to change all oils to new ones), got confidence in my truck, got her registered (at least!!!).
and now the second phase arrives, how to build the best possible (for me) camper out of it?
Thanks for any reactions.
1989 F-350 7.3IDI 4x4 ex US AIRFORCE ambulance.
__________________
greetings, Bart
__________________
greetings, Bart
