T-19 gear ratios and shift points
PossumTruck
Michigan
(I have no tach, so MPH is really my gauge) What exactly are the shift points for a 6.9L with a t-19? Specifically, I'm working through losing a power bad in the 3-4 shift. At one point, I was doing research and was told about 35 mph was the high end for 3rd gear. I knew that wasn't right because I could run it to 45 when I wanted (and the engine sounded loud), but it drove better that way. Rear axle is a Sterling with a 3.55.
My issue has been that the 3-4 is basically that I lose power as soon as I shift to 4 - and in a way that seemed odd/pathetic.
I could strain on the road to keep 55 on a steep hill, unloaded. Unburnt fuel cloud and all.
Today I took 3rd gear over 50 mph a few times, sure made the 3-4 better, but my reading/research has told me that is way too fast.
Any insights? Truck is a Cab & chassis, not sure if that has an effect on the ratios or if my research was bunk.
u2slow
bilge rat
PNW
Whatever anyone says, needs to be qualified with an axle ratio (assuming a certain tire size.)
Sounds like you're geared 'tall'. 3.54 and 4.10 are the most common ford ratios.
Have you turned up the fuel? That helps the power. Good idea to get a pyrometer though.
ROCK HARVEY
Dayton OH
You can play around with this gear ratio RPM calculator from spicer to see what your speed is at various RPMs: https://spicerparts.com/calculators/transmission-ratio-rpm-calculator
3rd gear in a T-19 is 1.41:1, so assuming 4:10 gears and 33” tires, you would only be doing 2050RPM at 35mph. 45mph would be 2650, and 50 would be 2950RPM. Of course if your tires/axle are different so will your RPM
ROCK HARVEY
Dayton OH
With 3.53 gears, you’re only at 1780RPM in 3rd doing 35mph. If you shift into 4th at that point, you’re entering 4th gear at only 1260RPM. You can definitely stay in 3rd longer.
That being said, I shift into 4th around that RPM all the time and don’t feel like I’m lacking power. I wonder if your timing is slightly off or your injectors/pump are wearing out.
PossumTruck
Michigan
holy cow I was way off. For in town and regular driving, short shifting is never an issue, but there are some long/steep grades in my normal driving that always annoyed me. I was just never certain as to where I should be cautious with the rpms. My ear-tach was being quite the nanny. 55 MPH is just under 3K rpms, so I assume safe if redline is 3500-3800.
It has a governor, so don't worry about over revving the engine going up hill. You do need to watch it going downhill though.
FrozenMerc
SW Missouri
See the chart below. I created this in Excel to understand where my truck is at. I have a T19 with an Advance Adaptors Ranger Gear Splitter (27% Overdrive, dotted lines), and a 4.11 Rear axle, spinning 31" tall tires. Really, the 2-3 shift is the biggest gap. About a 1200 rpm drop in my truck with a 4.11 rear. I typically shift between 2500 and 2800 rpms (Black Line), unless I am puttering around town. This means shifting at 15, 25, and 45, (unless I have a trailer on, then I like to split 2 and 3 as well). With the over drive, there is one more shift between 55 and 60.
Here is the same chart for a 3.55 rear end and the Overdrive removed. Shift points are now 18, 30, and 52.
u2slow
bilge rat
PNW
Honestly, i think you'll like a tach more than trying to shift by the speedo.
PossumTruck
Michigan
Frozen Merc: That is incredible. thanks!
U2slow: Working on it. The ~$200 they are asking on ebay is just off-putting to me. I have a sensor to screw in and I think I have the circuit board to enable a Tach if all I could get is a tach (no cluster).
PossumTruck
Michigan
Injectors are newish, pump is from before I got the beast in 2019, so unknown there. All things are possible culprits, but knowing how hard I can run it will certainly help.
PossumTruck
Michigan
Update for internet/history/completeness/purposes. I put into action the 18-30-52 shift points and it worked beautifully. Thank you.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
I have a factory tach on my 86, T19, 3.54s and 31' tires. 3100 rpm @ 55 mph in 3rd, perfectly safe :Thumbs Up
KansasIDI
Wilsey, KS
I grew up around Cummins and Cats, so spinning an old diesel engine that fast kinda scared me at first... Then I drove a 2 stroke Detroit and now high revving diesel engines don't scare me anymore LOL Everybody's gassers spin faster than this anyway and they hold up, at least in stock form
