ironworker40
NYC Ironworker
My Napa sells those speednuts for the bolts for the core support in bags of 10. I think there are only 2 sizes on the whole clip. Bring them with you to match up. You can get them in american thread and ditch the metric bolts if that helps. Never sieze all bolts when going back together. I used high temp never sieze on exhaust bolts and on slip fit turbo pipe's. Make sure downpipe is out when dropping motor in. This will let trans go higher. If you leave clutch fork out you can see trans imput shaft thru the hole for the fork the aid in line up. DONT FORGET TO PUT THE RELEASE BEARING ON THE TRANS INPUT SHAFT facing the correct way. Double check it.
