Lemme clear some misunderstandings here.
The idea that superchargers are terrible for diesels is a complete lie for these IDI's so don't make judgement on something you have no experience with.
Here's why I think Superchargers are ideal for our trucks:
You get more horses at lower rpm's, flattening out the the power curve
You don't have any restriction on the exhaust, making less compression in the engine: lower EGTs and no need for head studs
You can easily customize how much psi you want by quickly changing your pulley size
You can supercharge our engine for 1/10 of the price of a turbo (Yes I have done BOTH)
Why you shouldn't Supercharge:
There is almost no build help, you are kinda on your own with these kinds of projects
You do not have experience with fabrication and or lack a welder and proper equipment
If you are paying someone to give your truck forced induction, then go ahead, go with a turbo because although it is going to be expensive, it would probably be cheaper than having someone fab up everything you need for your supercharger install
To be clear, you do not "loose all your boost at higher rpms" I loose four psi from taking off to 3rd gear @3700 rpms- its all in how you setup your supercharger, I could see maybe a loss of ten psi if you were using a supercharger for a little 4 banger
All in all green machine, I asked this same question months ago and received the same answer, but maybe this will be some help in giving you some info from all angles! Sorry if this offended people btw, not trying to tick anyone off, just stating facts.
