Dieselpowerking
I replaced my back leaf spring that was broken and another front leaf spring but the truck still leans 1/2inch to the passenger side anyone else have any ideas?
Have ever had the truck on the frame rack? Any body panels look like they’ve been replaced?
How do your body mounts look?
Never had it on a frame rack. When I bought it it was consider a total loss but has a clean title and doesn't say what happened to it. The box has been replaced at some point and so has the tail gate and it has been repainted. I was thinking the frame was bent but that's hard for me to believe if it has a clean title.
Total loss by who? Titles and Carfax reports are only worth the paper they are printed on. It's easy to total a truck, not well anyone and throw some lipstick and mascara on it and send it down the road.
If it looks like the box has been replaced I'd bet it's got a bent frame..
Both sides should be intact, the bottom takes more load than the top. I would get it on a frame rack, I’ve seen pretty sketchy trucks still on the road with a clean title when they had no buisness doing so.
Isn't the issue a complete lean? Not just one corner higher than the other? I'm trying to imagine what sort of bend/twist would cause the entire side to be higher/lower.
Old ball joints on one side might cause a lean.
