NapaBavarian
Dually driver 6.9
What should I look for? I havn't oiled the throttle cable yet, I assume that would be a good start, but is there anything else I should look for? It also pops when I roll on from closed.
If it feels stiff, its time for a change. goto ford, pay your $57 or $75, and be done. Its a metal wire in a nylon housing and with those bends it goes through, wearout is a certainty. Better to change it now than when it seizes up on you. the P/N is in the "parts bin" article.NapaBavarian said:What should I look for? I havn't oiled the throttle cable yet, I assume that would be a good start, but is there anything else I should look for? It also pops when I roll on from closed.
fiverpuller said:The popping might be from the plastic sheaths catching on each other up by the IP. Mine was cracked up and popped. Take a look and it might make more sense.
