Sterling axle stupid noob question
laserjock
Almost there...
Okay, my manual is leaving me stranded here. I'm trying to put my axle shafts back together and install them. I night these.
Last night when I started cleaning the flanges up, I realized there were crusty orings hiding in there. I found replacements.
Do I use the gaskets too (which are metal btw) and if so which way do I turn the ridge? The axles didn't have gaskets on them much to my surprise. Manual says replace with new o-ring or gasket. Is using both a problem or il-advised?
Thanks!
crash-harris
Breaker! Breaker!
Chillicothe, OH
IIRC, those don't get used. Mock them up and see if they fit. I know mine didn't and it had been too long to return them, so they got chucked in a pile somewhere. Still no leaks.
I would stick with oring.
I bought those and lathered em up with elephant snot without test fitting. Yeah they didn't fit. Lol
dunk
Dunce
NJ
Indeed. Orings only, never had one leak from there. Be sure to use the two piece stat-o-seal type seal for the hub to spindle. The older style once piece seals are expensive and always leak.
Ole BlackBetty
Norman, Oklahoma
What are these seals and where do you get them, I have replaced one of mine twice and it still leaks, at the tune of about 45.00 a piece
Sent from my SAMSUNG-SM-N910A using Tapatalk
MTKirk
Billings, MT
laserjock
Almost there...
I picked mine up from rock auto I think. It's an SKF Scot seal I used. If you hit my build thread, I think the part numbers are there. Did them not that long ago.
X2 on axle tube vent.
Koch13351
SoCal
I use a thin bead of Ultra Black RTV because it's a helluva lot cheaper and works perfectly.
truckonfire
