acey4342
Sorry if there was already a post on this one, but I have a few questions for you idi folks. #1 on an 86 6.9 idi will the glow plug light come and appear to work when it actually does not heat the glow plugs (is this possible) it does however come on for 8.5 seconds in temps of approx 80 degrees f.
#2 if you were going to install a check valve on the suction side of the lift pump to keepthe ip primed and prevent leakdown what kind of valve is best and where would you buy one? Thanks in advance!
