special tool required???
jimraelee
Gaston, OR
It seems I have developed a flat spot in my RPM range. I wouldn't think a motor with 60k would have injector issues, but..... So I'm thinking of swapping out the injectors and maybe the IP with some rebuilt units. Are there any special sockets required to pull the injectors on our idi's???
No. And go to Diesel Fuel Injection Service
(503) 235-1947 MArk is the owner.
Tell them I sent you. You will get a good job.
They will test the nozzles for free. Also how is the fuel filter?
jimraelee
Gaston, OR
Ok Russ, thx for reference for DFI, will do. I'd be tempted to pull mine out and take them over, but its my daily driver. I'm thinking a new set would be easier for downtime. Fuel filter is good just changed it 10k ago. butttt with the WMO I sometimes run, I should probably swap it out sooner than 15k mark. I do filter the WMO with a sock down to 1micron, but who knows.
tractorman86
Buckeye, AZ
15k! i dont dare let mine go that long, maybe 6-8 if i dont have the time but usually only about 5.(it may be over kill but i never have to worry about it)
jimraelee
Gaston, OR
Oh I never thought it should be changed sooner. But if you figure fuel fitlers are good for a year of avg driving, and avg driving is 15k miles a year. I guess its about avg cycle time. Maybe I should change it out and see if things improve.
Always change the filter first when you have a power problem. All my latest fuel problems were filter/bad fuel related.
punkmechanic
diesel tech
North East Portland Or
jimraelee, I have a set of injectors that I can drop off at dfi for you. When mark is done with them you can pick em up, swap them in and then give me your old one's ( i like haveing spare parts around). just shoot me a pm or something and let me know.
punk
jimraelee
Gaston, OR
thanks Punk. I'm going to swap filters first. I will keep you in mind. That would save me from having to buy a set. thanks.
