Sourcing WMO
I get either 55 gallon drums from my scrap guy,
or you can use a plastic tank.
as far as lifting 55 gallon drums, I have an attachmet for my forklift that cradles the drum when you lift it. works great.
janssen
Ontario/Canada
I used a home hardware gear pump, coupled to a old electric motor.
Try this method - not the best but works for a cheap - give it a whirl without lots of input costs. Pump is handy to have anyways.
Use a 30 micron filter inline on the suction side when picking up the oil,
let is settle for 2 days for water removal,
USe a 5 micron inline sucking off the top into a second barrel with 30 liters of gas already in it
Pump into truck through 1-2 micron filter - can't use Wh filters here - the gas will chew them up.
Done. Should be under 4 bills.
Great test, if it works use your savings to improve system. I did it like this for quite awhile.
https://www.homehardware.ca/en/rec/...ears/3-4-Brass-Gear-Pump/_/N-ntjbk/R-I3120050
https://www.homehardware.ca/en/rec/...Ne-67n/Ntk-All_EN/R-I3115854?Ntt=water+filter
https://www.homehardware.ca/en/rec/...Ntk-All_EN/R-I3115159?Ntt=RAINFRESH+cartridge
On your truck put a secondary filter in:
P551313 from Donaldson which is better than 3um
Outer Diameter:
3.66 Inches (93 MM)
Thread Size:
1-14 UN
Length:
6.97 Inches (177 MM)
Gasket OD:
2.83 Inches (72 MM)
Gasket ID:
2.44 Inches (62 MM)
Efficiency 99%:
3 Micron
Efficiency Test Std:
SAE J1858
Type:
Secondary
Style:
Spin-On
Media Type:
Cellulose
Brand:Wix Filters
Manufacturer's Part Number:24770
Part Type:Oil Filter Mounts
Product Line:WIX Filters Remote Oil Filter Mounts
Summit Racing Part Number:WIX-24770
UPC:00765809247703
Remote Oil Filter Bracket Style:Single
Oil Filter Thread Size:1-14 in.
Inlet Quantity:Two
Inlet Attachment:Female threads
Inlet Size:1/2 in. NPT
Outlet Quantity:Two
Outlet Attachment:Female threads
Outlet Size:1/2 in. NPT
Oil Filter Bracket Material:Cast aluminum
Oil Filter Bracket Finish:Natural
Quantity:Sold individually.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
m67tang
lawrenceburg IN
To the OP- what part of the states are you in. I'm looking to share some excess in the Cincinnati OH area....
IDIBronco86
