vegas39
I just spent the whole day yeasterday removing the block from my 89, removed the complete good running motor from my 86 and transplanted it into my 89.
Now heres the problem. The engine is spraying water out of the back of the passenger side head and ******* a little out the exhaust, this is the 6.9 that we put ARP studs in about 40,000 miles ago.
My cousin in law did most of the work and I remember, he did not pre stretch the studs as ARP recommends. He was told that by using the ARP assembly lube, that the prestretch tighten and loosen several times, was not needed.
I was driving the old 86 for the past two weeks with no issues, until we pulled it and stuck it in my other truck. How could a head gasket go so bad by just transfering the engine from one truck to another.
So I pulled the head off today and can see where the coolant was leaking past the gasket to the outside of the block and I also saw its path into the cylinder.
I am going to re install the head tomorrow but am curious how to re use these ARP studs, do I just reinstall them and do the torque sequence? I dont have any ARP assembly lube.
I also remember that we didnt tighten these much more than 80 pounds when we installed them a few years ago, should I go tighter?
Last, should I retourque the other head before it gives a problem? Thanks!
