sle2115
NRA LIFE MEMBER
Yes, Dana 44 TTB. I will have to say that your rig would be an exception to the common experience. I've only driven older Fords. Every TTB 4x4 I've had has been one head ache after the other. The ball joints don't last and they are a PITA to replace. The bushing wear out, the allignment never holds for long, and the TTB set up wonders all other the place once these parts start to wear out. You're lucky, I've had only problems with the TTB. The ride quality if the solid 60 is no worse than the TTB, at least in my experience. The 60 in my opinion (you know what they say about opinions) is a better all around axle.
Heath
I can't see any comparison at all. The D60 is used for all kinds of HD apps, rock crawling and such, and that is because it is a better axle. My truck, with F350 springs and the add a leaf's, drives like a corvette compared to the D44, it rides BETTER, not worse - even with the stiff springs. My wife has all kinds of back problems and will at least now ride in my truck on occaision, something she would never do before. The axle is also much better because there are less things to wear out, no pivot bushings etc. Just bearings, King Pins (which rarely wear out) and wheel u joints (2 in the D60 compared to 4 in the D44). On my swap, the only change I made after the axle install was to use the yoke and double cardon front drive shaft from the donor. It was all bolt in, no custom anything and as for getting the yoke off, there is no way it could have been easier to change the cross member! A 3/4 inch ratchet and 10 minutes, both removed and replaced - yep, took two off, put two on, one in the truck one the transfer case was out. By using that drive shaft, I also have tons of deflection so I can still raise my truck more if the desire hits me.
has a torsion bar also,do i need this if so where do i find the rod that attach it to the frame.
buy ya a burger and you say "hell with the map"
